can't wait to see it! do you need both driveshafts? i thought you could re-use the sct driveshaft in the front and only needed the longer rear one...
The posts came out amazing! I need to copy that. I’m going to order the parts right now. Wow!Thanks T-Buggy.
Here's some progress or if nothing else some time reading material
Front and rear installed on M2C Racing chassis. Diffs are done with PT Racing fluids with 15K front/10K rear. 1/8 scale diff couplers also installed.
Underside pic of the chassis. DE Racing rear skid installed to compliment the M2C chassis skid.
Center drive line installed. Center diff has Traxxas 500K diff fluid in it. Running composite spur. M2C Racing rear chassis brace. Both center driveshafts are aluminum. Trying to come in around 8lbs max when finished.
Savox 1270TG servo installed and dropped on the Tekno 25T servo horn. As you can see I have the .4 steering upgrade that is also ran on the MT410.
All wired up!! Hobbywing Xerun XR8 SCT ESC paired with 3660 3600KV Hobbywing motor. Running 3S and geared with a 14T Tekno pinion.
Cage is ready to be fitted. Had some ideas already going in. Lets see how it went
Went pretty damn well if you ask me Was able to configure some mounts to use the stock Nomad mounting holes and be able to use body clips or Pro-Line thumb screws.
Had some HPI Apache SC mounts laying around. HPI107429. Post spacing was spot on and they're very adjustable. Used a 3mm screw thru an unused shock mounting hole and a couple 3mm flanged nuts for spacers on the tower. Had to invert the front mount to clear the studs on the standoffs, but zero modding to the plastic mounts were needed. This was on the front.
For the rear I actually used an extra set of shock standoffs I had for spacing. Again just used an extra shock mounting hole on the tower. Used nuts as spacers on the 5mm side of the standoff where the shock cap bushing would sit and again needed no modding of the plastic. Washers and 3mm nuts and done.
My apologies for being brief, but I crammed a bunch of info in this post and wanted to touch briefly on what unfolded in the past 5 hours or so.
Suspension: Running stock SCT settings for kickup, antisquat, and toe. Running the aluminum A & C blocks at the moment. The shocks are also filled with PT fluids. 450CST front/300CST rear. Shocks are fully decked with all the Tekno aluminum upgrades. Delrin CNC'd internals, 8 x 1.3 pistons drilled to 1.5mm. For springs I went with the LF stock springs from the EB48.4 buggy. Orange in the rear/black up front. As long as I can get my desired ride height they will stay for testing because they feel nice and plush. Shocks are built emulsion style
That's it for night 1. Panels tomorrow while I'm charging packs for Friday's SCT racing.
One night? JFC that would take me a month or more. Looks Awesome.
looks beautiful... very tempting to convert my SCT410.1 if the 4WD SCT truly dies off in my area... the class has been on the fringe for a while now
I found the mounts and ordered 3. Never know if I’ll need them in the future lolThanks buddy! You know my speedy builds by now
Thanks Hye. Those posts may not be so easy to source either. I have used them in a few other builds so I had them on hand. I originally had intended to use the Nomad body mounts but of course are sold out everywhere as well.
Seems pretty dialed as it sits. It's definitely a blast to drive The HW combo seems great going slow or fast. Motor was 92 degrees after that run. May creep up some more but I can't see heat being an issue and may be able to gear up. Right now RTR minus panels and driver I'm at 8lbs .08oz. I'm assuming around 8.5lbs when it's finished.
Today was wheels & tires day
Freakin awesome test. Low, Mid and High speed seem perfect. Tires bite but are loose too. Maybe a little suspension and diff fluid test after the rock work. Looked to articulate well and kept the line 85% of the way. Very very nice so far. Look forward to hearing about your first race.
Awesome! You work fast. Mine will be done soon lol. What are your plans for panels?
Looking great Pauly!. I also have a set of Hyraxes on the lightweight aluminum GearHead wheels. I’ve had problems keeping the tires on the rims. I scuffed with scotch brite, cleaned the wheels and tire bead really well before glueing. CA glue just does not adhere to aluminum as well as it does to plastic. ....or maybe it’s because I ran 5s a few times. I’d stick to 3s with those wheels/tires if you want them to stay together.
Do you have a track that holds races for that class near you?
