Slogrits MT410 build.
Slogrits
Winston Salem
So I have ordered everything. The MT410 kit is back ordered along with the Futaba 3pv transmitter and receiver.
Parts acquired:
  • TKR6051 Shock Pistons
  • TKR7075 aluminum caps
  • TKR5060 servo brace
  • TKR5262 diff mount
  • TKR6146 cartridge set
  • TKR6015 cartridge caps
  • TKR5115 Spur gear
  • TKR5253B 15T Servo horn
  • TKR8767 front shock spring orange
  • TKR6083 rear shock spring
  • TKR6013 shock adj. nut
  • TKR4177 17t pinion
  • TKR5433 rear mud guards
  • Pro-Line Baja Bug Body
  • M2C center brace
  • M2C rear brace
  • M2C rear shock tower brace
  • Castle 1515 MMX Combo
  • Savox 1270TG
  • Pro-Line Shockwave tires (can’t find backflips)
  • Castle Creations motor fan.
  • T-Bone stunt truck bumper
  • T-Bone XV4 front bumper
I probably missed something things are still on the way. I impatiently painted the body gave a good coat of Plasti Dip and then gave it the old Gorilla tape goto.
It's always nice to have all the parts ahead of time and be waiting on the vehicle. I made the opposite mistake and had the car and then was waiting on the 3-4 week delivery on the servo. Sounds like this thing is going to be pretty modded out from the start. Keep us updated on the build!
I will update as I go. I slowly ordered the parts over a 2 to 3 month period. I will add the M2C upper shock tower brace if it ever comes available. I will use your tip on the washers until then.
Well thought out build. Its definitely a better way to upgrade as you build rather than tearing down and doing things twice IMO.
Agreed with the above. Hate to read an upgrade thread that only has I upgraded the blah blah with a alum blah blah. Manufacturers and PN makes the reader feel like you GaS and want to help out so Kudos to you for that.
Look forward to it all coming together. After all those upgrades doubt you'll need anything else other than more batteries and bodies.
did you go with the new sensored 1515?
I think it is the newest. Unless something came out in the past month. 1515 2200kv with monster mamba X esc. My Dad has it in his MT410 and it is a beast on 4s with a 17t pinion. There is not really any room to hook up the sensored connections. He is running sensorless.
M2c center diffs back in stock. Just ordered it. I guess I will skip step one when I start my build tomorrow.
let us know how it looks, curious to see if it's a new revision and what changes they made to improve it...
Pretty certain he's talking the aluminum diff cases. Mitch said they're back in stock on FB today. Don't think they revised those.
Oops yeah diffs not brace. I guess I saw what I wanted to see!
Those diff cases are nice looking too.
Here is where I started my build today. It’s my dads lair that I will be taking over for a bit.
Further into the build. I have used the shock tool a ton so far with all the ball ends. Even used the 17mm portion when I righted the hubs. Trying to stay organized I labeled everything. Then if I have to fix something later I won’t guess.
Here’s where I stopped at midnight. I might work on it tomorrow.
Yea center diff.
Worked on this on and off today got a lot further than I thought I would. The TBR Bumpers took a little to figure them out during the build. I had to you tube it. M2C center diff arrives tomorrow. I can finish the steps I skipped.
The M2C center diff came in. M2C still doesn’t have the upper shock tower braces, so I made these out of mending plate. It’s pretty ridged so it shouldn’t pull through. I should be complete with the build today.
Finished. Today, first run after work. I will be watching the clock all day.
