cr8tor
You may remember me from a previous thread asking for pre-build thoughts on my parts list.
I appreciated all the feedback i received. It was very helpful.
Now i'm back for the post build advice.
Comment on some or all topics, anything is welcomed.
I'll figure it all out on my own eventually, but pointers, suggestions, links to videos and setup threads are always welcomed and appreciated!
While i may figure it out on my own, i very value the input of people that have been there before.
First, a pic of the completed build. I just wrapped it up, bound the transmitter, verified all worked, and clicked the pic.
In case you noticed it, the pinion is not installed yet to avoid accidents while i play with and learn the electronics.
A habit from working with racing drones and 700 series helicopters that chew things up and/or simply disappear at a rapid pace.
My build list is as follows.
So what all should be on my list of things to do next?
I've listed items i am already planning.
- MT410 Kit
- Nitro Pro 650 (too tall, had to be shimmed to fit, buy the 550 instead)
- Castle Creations Monster X 1/8 Brushless Combo w/1515 Sensored Motor (2200Kv)
- Tekno RC "M5" Hardened Steel Mod1 Pinion Gear w/5mm Bore (16T)
- ARRMA Backflip Lp 4S 3.8
- Pro-Line 2017 Ford F-150 Raptor
- DX5C Smart 5-Channel Transmitter / SR315 Rx Combo
Mount power switch somewhereSet endpoints for steering- DoneCenter the steering?(adjusted mechanically via control arm)It seems pretty close right now but this is my first terrain vehicle for over 10 years.
Adjust shocks/ride height/Droop- The Castle Link Adapter is ordered
- Once received, update and customize motor/esc settings as desired
- Any settings to change from stock that you might recommend?
- I'll be watching videos and learning more about this while i wait for the adapter, video suggestions or reading material links welcome
- Suggested settings
- Disabled drag brake
- Set brake power to 30%
- Enable 20% punch control
- Enable the auxiliary feature for max throttle
- Change the sample size for data logging to the lowest option to accumulate more runs worth of data
- Shorten and customize wiring as needed/desired.
- Is there any reason not to shorten the 3 motor to esc power cables?
- Is there any reason not to shorten the motor sensor wires?
- Secure sensor and control wiring connections
- Dab of hot glue to hold them in place
- Body is in progress also
- Paint - The wife paints so i have all sorts of acrylics to use
- Then i'll shoe goo and drywall mesh the inside of it
- Then drill holes and mount
- Keep an eye on motor temps to determine if a heatsink or heatsink/fan combo are needed, or possibly a different pinion
- Keep an eye out for loose screws (on the vehicle)
