cadon78
Detachable Member
I come to those who have done his before as this is my first time building this amazing machine. I am just starting to finally build it. I bought the m2c racing dif cases and the center is fine and the rear is fine, however when I built the front dif and screwed it together it’s locked up tight. I then took the shins out thinking maybe it was those, no change. I’m using the stock 10k oil. I figured maybe I did something wrong. I then took it all apart and built it in the case that came in the kit. It’s buttery smooth. I mean perfect smoothness.
I have emailed Mitch and just waiting on a response. I’m wondering if maybe it was just a bad one with incorrect clearances or I’m just crazy LOL!
What do you guys think? I don’t mind only running the center and rear in the m2c cases if I have to, or I could just put it all in the kit cases and be done with it.
