Yes, if you are running 4s the plastic in the center diff will break.You mean TKR5149 & TKR5150 are more strong ?
My motor 3300KV, 4S battery , then... all the tires are blown !Yes, if you are running 4s the plastic in the center diff will break.
If you are running 2s, you should be fine with the stock grears.
I'm running a HW 4268 2200kv motor/ 16th tooth pinion in my sct410.
LOL yeah, I'd beef up your gears and get some proper 1/8 tiresMy motor 3300KV, 4S battery , then... all the tires are blown !
Oh, my. You got another motor on order?
Hi, I have the M2C7017 on the SCT410 2.0. Fit perfectly and everything is needed. However, have +5mm offset.I’m planning to convert my Tekno SCT410 2.0 from 12mm hex hubs to 17mm hex hubs so I can use a different set of wheels. Other than TKR5569, TKR9588, and the set screws, are there any additional parts I need to purchase for this conversion?
Claude suggests (after much prompting to shut down some hallucinatory answers) that the M5 threads are good for something during production and have no use after that. I lack the expertise to contradict this idea.Can someone explain why the TKR9588 has M5 threads at the end of the axle, then these stop and M4 threads begin and extend past where the pin penetrates the axle. The result is that you use an M4 set screw to attach the hub, OK ... but then what use are the M5 threads?
What are you trying to do?Claude suggests (after much prompting to shut down some hallucinatory answers) that the M5 threads are good for something during production and have no use after that. I lack the expertise to contradict this idea.
Does Tekno sell the 2.5x12mm pins (that come with the TKR5569) separately? Plain pins are easy to find from others, but I don't see any with the center flat pre-ground.
Seems like that is the best option and high quality. Easy button if you will.Hi, I have the M2C7017 on the SCT410 2.0. Fit perfectly and everything is needed. However, have +5mm offset.
I would like to have a spare for this part. I know myself and could easily lose one. I've bought a plain pin and ground the flat onto it. No big deal but I'd rather have bought a Tekno part.What are you trying to do?
pins will come with the hexs like TKR5569.
you will need to buy the M4x4mm set screws that go into the drive shaft end seperatly (TKR1602) if your drive shaft requires it, what part number are your trying to install?
Drive shaft > hexs (comes with pins) > set screw
Edit* if I remember correctly I went with TKR5570-17 & TKR9588, there is a couple of other part combos to get to the same place. depends how wide your want the front track on the car
go to jennysrc.com and buy the set of hex/pins/and screws, its like 12 dollarsI would like to have a spare for this part. I know myself and could easily lose one. I've bought a plain pin and ground the flat onto it. No big deal but I'd rather have bought a Tekno part.
