410 2.0 Convert my Tekno SCT410 2.0 from 12mm hex hubs to 17mm
You've done your homework. I don't see where the hexes say they come with wheel nuts. They will be the same wheel nuts that come on the 48 trucks.
I think you are missing TKR1602 (dont forget Loctite on these)
Also if you are running 4s, change the center diff gears with the TKR5149 & TKR5150
Yes, if you are running 4s the plastic in the center diff will break.
If you are running 2s, you should be fine with the stock grears.
I'm running a HW 4268 2200kv motor/ 16th tooth pinion in my sct410.
My motor 3300KV, 4S battery , then... all the tires are blown !:LOL::LOL:
I’m planning to convert my Tekno SCT410 2.0 from 12mm hex hubs to 17mm hex hubs so I can use a different set of wheels. Other than TKR5569, TKR9588, and the set screws, are there any additional parts I need to purchase for this conversion?
Hi, I have the M2C7017 on the SCT410 2.0. Fit perfectly and everything is needed. However, have +5mm offset.
Can someone explain why the TKR9588 has M5 threads at the end of the axle, then these stop and M4 threads begin and extend past where the pin penetrates the axle. The result is that you use an M4 set screw to attach the hub, OK ... but then what use are the M5 threads?
