Yes, if you are running 4s the plastic in the center diff will break.You mean TKR5149 & TKR5150 are more strong ?
My motor 3300KV, 4S battery , then... all the tires are blown !Yes, if you are running 4s the plastic in the center diff will break.
If you are running 2s, you should be fine with the stock grears.
I'm running a HW 4268 2200kv motor/ 16th tooth pinion in my sct410.
LOL yeah, I'd beef up your gears and get some proper 1/8 tiresMy motor 3300KV, 4S battery , then... all the tires are blown !
Oh, my. You got another motor on order?
Hi, I have the M2C7017 on the SCT410 2.0. Fit perfectly and everything is needed. However, have +5mm offset.I’m planning to convert my Tekno SCT410 2.0 from 12mm hex hubs to 17mm hex hubs so I can use a different set of wheels. Other than TKR5569, TKR9588, and the set screws, are there any additional parts I need to purchase for this conversion?
