Update for folks who are evaluating motor choices for their own builds.
For my build, I knew I would run 6s, and I relied on forum recommendations to select tires (
Arrma Backflips).
I selected a TPPower 4050 motor, aiming for a "middle of the road" result, which is to say, not quite at the overkill level, but way more power than a racer would run. The most important thing to me was the ability to run two battery packs, back-to-back (spoiler alert: I failed).
You can
read the motor specs on the website, but the important ones are:
--40x80mm (roughly)
--420 grams in weight
--5000 watt peak, 2350 watt continuous
--1700kv
I went with 1700kv because that number was roughly in the middle of the KV range for motors that were listed as being capable of handling 6s:
(TPPower website motor selection table)
So here's the part I got wrong: the ET48 being my first Tekno, I hadn't realized the 15t was about the smallest pinion that would fit without some amount of surgery (i.e. grinding the motor mount, or other modifications). Combining a 15t pinion with the Backflips (which are 6.8in in diameter) produces a relatively high final gear ratio.
So, although the performance I get is absolutely phenomenal, the motor temps are too high (around 190-200 degrees), and I definitely can't run two full packs back-to-back.
So far all my testing has been at 50-60 degrees ambient, so this problem will be worse by about 30 degrees in the summer.
Now, if I step down to a 6" diameter tire, or even 5.5" like a standard truggy tire, then I don't break 140 degrees on the motor.
I am currently using passive cooling only (i.e. a motor heatsink) because I know I can always get a final improvement in temps by adding fans, but I like to save that for last.
For those of you getting motors for your builds, you might want to think about which tires you will run, and if they're over 6" in diameter, you might need to lower your KVs to make up for that (because you can't correct the gear ratio with the pinion, below 15t). I think a 12-13t pinion would be ideal for this 1700k motor with the big 6.8in tires.
If you were running a longer can more (85, 88mm) you might be ok, though. That's probably my next motor, but I might still aim low on the KV because there is plenty of room to increase the size of the pinion gear, just not much room to decrease it.
Happy over-powering!
