Rear center outdrive leak 48sl
BpRc chef
I have 5 tekno rigs 2 are EB48SL both are spewing oil out the back center diff is there a puck design for the mini dog bone?
check your seals for any tears, could also be a squashed gasket that may need to be replaced too, if it's been over a year since you last replaced these items then I would go ahead and service them now. I like to use Super Lube on all my seals to prevent any leaks... also check for stripped threads on the diff case, if so then replace the case while you're at it ;)
See that the (plastic) sealed surfaces are clean and flat.
