I haven't really noticed that much of a difference.@Overkill Did the chassis change how the truggy handled in the air? I have ordered one and it will be here wed but just wanted to ask. The stock truck flys so well it is amazing how stable it acts in the air.
With my other truggy, I use the stock ESC plate as a rear motor support. I use 20/43 gearing and the motor rests right on the plate, it works really well. With the truggy in this post, I did try a fan mount support but it didn't hold up on big jumps.@Overkill I bought a 107mm TP Power 1700kv motor for my wide chassis. Do you think I should support the back end of the motor with something?
I swear I saw you used a fan mount, but cannot seem to find that picture again.
My motor screws are 4mm and I have the older style M3/M4 Tekno mount.
Thanks!!
I'm using the Tekin 24mm horn, but I don't think they make that length anymore. It's not going to hurt anything if the linkage rod isn't completely level.What servo horn did you end up going with? I picked up the Protek 7800BK like on the website but I don't see anyway to use it unless I put a huge amount of washers on the steering side to level out the linkage. I can't seem to find M2C own servo horn anywhere either.
Good to hear. I'm running the Voltage Hobbies rear skid plate, works great. I know a lot of people who run this chassis, they're just not active online. Glad to help
Yes sir. It needs to be cut and I use gorilla tape.Thanks big time man going to order one, does that body come precut? I have one for my sons Mugen I love how thick the lexan is. Dang hated I wasted this factory Tekno NT48.3 body and all the shoe goop. Do you mess with shoe gooping your bodies?
@Overkill did you go with higher weight springs? My truggy with this new chassis, larger 107mm motor, and Max6 ESC is sitting really low in the travel with the stock green springs.
Thanks!
