Thnaks alot, i'll take them apart and inspect the O-ring!Which style shock caps? Emulsion? Bladder?
Regardless make sure that the seal (o-ring if emulsion, bladder otherwise) is seated properly. I overtightened my shock caps and pushed the bladder out of its seat, causing the shock oil to all leak out via the bleeder hole.
You can build any type of shocks with these caps. Just don’t use the large o ring if you use a bladder.I bought the EMULSION with the shock cap O ring and the tiny O ring and grub screw priced at 22.97 through AMAIN!
I think you also have to restrict the stroke a bit so the shaft doesn't pierce the bladder.You can build any type of shocks with these caps. Just don’t use the large o ring if you use a bladder.
