48 2.2 ET48 2.2 Basher Build
HulkRC
Finally posting my ET48 2.2 basher build. Build was enjoyable and straight forward. Like the way the ET48 2.2 drives, handles and flies. Very stable and well balanced. Durability is very good relative to my Arrma 6s bashers. Only stripped out wing mount screws from bulkhead upon landing on the wing mount. Eventually I may upgrade to ADU aluminum bulkheads. Excellent rig to complement my MT48 2.0.
If you plan on sending that to the moon, may I suggest some heavier shock springs. The stock springs are pretty soft, even for racing. I would think you would want to go up a couple spring rates for bashing.
Not sending it to the moon, leaving that for my other bashing rigs. But ordered Tekno orange springs and will be using 910 cst shock oils in all four. Also used thicker diff oils. Stock oils for racing.
I recommend the ADU gearboxes. I have one on the rear of my MT48. Since installing the gearbox I have stopped rounding off ring gear teeth in the back. Vitavon also make gearboxes for Teknos.
Very nice! I would consider getting an Aluminium steering top plate/brace. Combined with the AllRacing centre chassis brace it strengthens the car from front tower to the centre diff.
Both M2C and All Racing braces suffer from the same problem. The material on the upper front mount is too thin. I've broken 2 M2C braces on my ET48.3 and a All Racing on my ET48 2.0. By the way All Racing is out of business. Old stock is the only stock.
That will probably be my next upgrade.
Another good upgrade. M2C makes one as well.
You must send it! Hopefully ADU, Vitavon, or M2C will step up to replace All Racing center brace as it is an essential upgrade for bashing.
It's true the 2.2 uses a step softer spring on the front/two steps harder on the rear (compared to the 2.0), but letting the oil and pistons do their suspension damping duties should be top priority. Tune them for your platform's needs. Springs do very little to slow down a suspension that's compressing.
