Tekno has another upgrade available for the Tekno EB410 buggy, now universal driveshafts are available!
The EB410 universal driveshafts are CNC milled from lightweight steel alloy and then black oxidized for wear resistance. An added benefit is that basic design of a universal driveshaft means little to no maintenance is required as dirt and dust won't cause issues with the joint.
Part Numbers:
- TKR6688 – Universal Driveshaft Set (rear, 69mm, EB410, 2pcs)
- TKR6687 – Universal Driveshaft Set (front, 77.5mm, EB410, 2pcs)
EB410 Universal Driveshafts Features
- Improved handling in rough or bumpy conditions
- Increased side bite in corners
- CNC machined and black coated for wear resistance
- Lightweight and virtually maintenance-free
The rear EB410 universal driveshaft (TKR6688) requires (2) 8x14x4mm bearings (TKRBB08144), one for each wheel hub assembly. To completely outfit the EB410 with universal drive shafts TKR6687 must also be used in the rear of the vehicle along with two additional 8x14x4mm bearings.
Get more info about the new EB410 driveshafts here.
