Redrumracing
Just finished ET48 2.0 build with the Tekin RX8 GEN3 combo with 1900kv T8 motor. ESC failed in less than 10 mins on the track. LED flashing 1,2,6,8 and according to manual it is a short. Soldering is fine, sensor wire is perfect. I don’t have another motor I can hook up to the ESC to eliminate a motor issue. Nothing was hot at all. I tried looking on Tekin forums and found nothing. Looked on you tube and found 1 person with same issue and they said their ESC shorted out internally. Curious if anyone else has had a similar issue. Thanks!
