Regular Wear or a Problem?
Will
So I noticed this wear in my rear axels EB410 and I assume that putting a small shim on the shocks is the answer or am I not approaching this from the right thought process? Thanks in advance for your help.
I had the same issue as well, I also placed shims to back the shocks away from the shafts, but this also changes the geometry and can add more rear grip to the point that might start to traction roll, if this happens then consider increasing the sway bar thickness by a tenth.
Thanks. That makes sense.
another option is to shorten the wheelbase which will also be a more drastic change to the geometry, I found the shorter wheelbase a lot easier to drive actually :)
