OG MT410 build 2025
Hubs were cleaned and new bearings installed
Finished installing the drive shafts were replaced with M2C shafts. Hubs were cleaned and greased. That's enough for today. It is taking twice as long to build due to cleaning parts and fitting them
Cleaned and rebuilt front hubs M2C driveshafts have been added and bearings replaced
I'm somewhat in the same mindset, where I want to find a MT410 V1 as well.
But I already have one that I built six years ago. Added a ton o' stuff and upgrades and let it sit. Recently moved to a area where there are more options for using it, so it's getting dusted off and readied for use. That one is set up for road use however.
I have a lot of parts. Diffs, aluminum bulkheads and plenty of other items. I'll build a basher at one point or another, but I know that OG MT410s are populating closets and will be available when their owners determine the best avenue is to sell. There are probably a few more years of that.
Good luck with your build, solaris!
Fitted the m2c goodies. I also replaced the steering assembly 90% new parts was missing an oring and bearings were worn. New servosaver as well
Servo installed chose to use nuts and bolts instead of the little plastic thread insert not sure what it's technical name is
Castle 1520 motor installed with a 20t pinion installed. Going to be running this on 8000mah 4s battery. Onyx extreme Graphene battery.
Thank you very much looking forward to running it. Glad to hear you are dusting yours off for use again enjoy the bashing.
Very nice indeed! What sort of weight is this tank now?
The weight is 3.7kg for reference my mt410 2.0 10th scale weighs 2.9kg without a battery in it. Both weights are without wheels
My battery weighs 648g so both weights aren't too far off each other.
3.7kg No battery, no wheels?
I'll weigh again with no battery and no wheels
Mt410 og
3146g
Mt410 2.0 10th scale
2977g
Roughly about 200g between eachother as I don't have a shell on the original mt410
Don't have the shocks installed yet
Changed shock fluid and used the new revised shock mounts. They reduce wear with the shock cap.
