Need Help With Exploding Spider Gears
bbbowers
EB48, MT410
Did you figure it out? I haven't had any issues with mine or my kids. Been hitting 20+ foot jumps, running up trees, backflipping with the backflip tires, with a 4s tekin setup. Never had any issues with the diffs. My son is a new driver so he still has rough landings at throttle and still no issues.
ZUMA
Chicago, IL
MT410
Not sure haven't taken it out. Winter is basically here in Chicago and I really don't run in the winter. So should find out in the spring.
Justin1975
I ran the crap out of mine so far. Way better. The action stays the same all run. I didn't realize that was an issue. So more fluid is definitely better. No flex at all. All the plastic cases were wore where spider gears sit. This would definitely cause gears to not mesh properly. A super thin shim between plastic and gears would do the trick. But as soon as they heat up and soften a bit, twisting occurs and the gears bind. Pop!
Jrbkeb2015
I have already had 2 diffs go bad on me within 7 runs. With stock diffs the rear diff blew out first after 4 runs. I figured I’d put in some M2C diff cups and upgrade my diffs. They came in and I installed all 3. Got 3 runs in and the front diff blew out. Both times it has been the spider gears, it looks like they basically exploded. I am running 6S but was thinking the upgraded diff cups would help them last longer. Any ways to prevent this on 6S?
Did you ever get this figured out? I just built mt tekno mt 410 and I've only ran it once yup thats what i said once smh couldn't figure out what was going on my truck just started acting like it was cogging and now i know why it was because the diffs gears broke just like yours the spider gears. I really hope this was just a fluke and doesnt become a frequent thing i bought this truck brand new built it to the T of the Manuel ive heard so many awesome things about this truck go figure this would happen to me
ZUMA
Chicago, IL
MT410
I'm not sure because I have only ran it a few times after replacing the gears. But I'm thinking the original gears that came with the kit were the problem, that's what I am hoping. The original gears lasted 4 runs on the rear diff and 7 runs on the front diff. So far on the new gears I am on 5 runs on the rear diff and 2 runs on the front diff. So far no problems with the center diff gears.
Ifti
UK
EB48
Have you opened up the diffs since you installed the new gears?
I would be tempted to open just to inspect their condition following a few runs.....
cAn”t DrIv3 4 sH!t cOol Need help with hobbywing xr10 g2 esc/ WiFi module EB410 2
cAn”t DrIv3 4 sH!t cOol Need help picking cap pack Electronics 3
Sscheitel MT410 New Build. Need newbie help MT410 0
ZUMA Need Help Picking a Transmitter and Receiver Electronics 9
B First MT410 Build !- Need Rollover Help MT410 6
arkus Why is my servo linkage at an angle? I need some help this doesn't look correct. MT410 11
Hye 410.3 Need help picking a motor to race with. SCT410 3
R How many channels do I really need? Electronics 4
Sludog MT410 build kit coming, need some motor buying advice MT410 11
piccopower Finishing up my MT410 build need advice please. MT410 6
A RC noob - Need recommendations for build ET48 4
H 48.4 Just bought one! What parts do i need on hand? EB48 1
Tamiyauberalles 48.4 Does anyone feel the need (and managed to fit) a fan on the motor in their buggy? EB48 7
Klappars 48.3 Buying ET48.3 soon. What parts will I need? ET48 9
S Need advice on gearing, already have a 15T pinion MT410 2
2 Just built my kit need electronics info ET48 13
Peejoe Arrma dogbone mod!! I have the driveshafts now what else do I need to complete this mod? MT410 2
C What all do i need to adjust voltage to servos? ET48 2
Jeb We need racers, come on up and have some fun! SCT410 6
cordell12 What other upgrades do I need? ET48 10
142Racing Need more on power steering EB48 3
Z I need a steering servo. Any suggestions? MT410 14
S Help me with tires! EB410 4
R Gap in Gearbox ? Front and Rear! - Help MT410 1
R MT410 newbie - Tire help?! MT410 6
J 48.3 Help with steering please (Eb48.3) EB48 7
ReMiXeDg Help with gearing tyvm MT410 5
B Help, sct410.3 replacement shocks.. SCT410 6
D 410.3 Worried about center diff, help? SCT410 4
Q 48.3 Build/Upgrades Help ET48 3
G Looking for EB410.1 base setup help EB410 2
405RCDad Help- rear inside tire lifting/ traction roll problem carpet EB410 4
Zvan Help with my MT410 diffs MT410 13
Ballistic1 Yes another newbie - plz help with choosing Tekin esc & motor ET410 2
Synthesis Help me make a small MT410 MT410 18
C Shock building help MT410 2
O She arrived :) little bit of help needed MT410 6
S Help with new ET48 build: o-rings ET48 3
J 48.3 Help me build a Speedster ... 48.3 EB48 8
mydogcouldeatyou mt to et chassis swap . help me find a body please MT410 14
cordell12 48.3 et48.3 Help me choose a motor and esc ET48 46
