410 2.0 Need help please!
T0m
Running a hobbywing quick run 10 BL 120 / 3660 combo on 2s with a 16 tooth mod 1. Why am I getting a studder on launch unless I feather the throttle. TYIA
What specific esc/motor combo did you get. There are multiple versions of this esc and motor KV. Maybe went to high on the motor KV? Might need to go down a couple teeth on the pinion? If a sensored version make sure the sensor wire connection is sound. Might need to go into the esc settings and reduce the punch and/or timing.
  • Like
Reactions: T0m
