Need some help mt410
Jordan 10
Hi I am new to tekno I am real active on the arrma fourm. But I came here because I am having trouble with the bell crack hitting the servo mount. It has the m2ç game changer chassis kit so it came with a different servo mount. Here is a video of what I am talking about. If anyone has any thoughts please let me know.
Some guys grind the bell crank. Pretty sure I’ve seen this mod somewhere.
Thanks for the reply I'll have to look into that. Maybe some else will chim in
Unfortunately this is the case with the m2c chassis. You can either set your EPA and loose some steering or grind the bell crank in that area.
Image is from @Overkill’s post in the Tekno MT410 fb group
Thanks I ended up grinding it down like picture above. I took just enough out so I could get the steering stops to hit. Then i adjusted end points from there.
