M2C V2 7075 Chassis Braces
Overkill
Birmingham, AL
M2C Racing has done it again! A huge thanks to Mitchell for his continued support in making Teknos indestructible. All of the chassis braces are now available in 7075 aluminum vs 6061 on the previous model.
The new front/center brace (M2C6905) is also a much beefier design with the upper cross bar added. It's designed to be used on either the stock chassis or M2C wide chassis, with extra clearance for the larger ESC's.
https://www.m2cracing.com/product.sc?productId=881&categoryId=114
3023
The new front/center MEGA brace (M2C6835) is designed to be used on the M2C wide chassis, where clearance is not an issue with any ESC.
https://www.m2cracing.com/product.sc?productId=932&categoryId=122
3024
The new rear/center ET brace (M2C6981) has also been re-designed to eliminate any potential bending if the two braces make contact with each other during extreme chassis flex.
https://www.m2cracing.com/product.sc?productId=917&categoryId=121
3069
The new rear/center MT brace (M2C6973) has been designed the same as above.
https://www.m2cracing.com/product.sc?productId=923&categoryId=114
3070
Holy moly that thing is thick. What does that thing weigh?
The M2C6905 front/center brace weighs 91 grams.
M2C V2 7075 Front/Center Chassis Brace
3071
V1 6061 vs V2 7075. The V2 also has the upper cross bar added.
3072
3073
I use a cap head screw at this intersection, it provides better clearance from the other brace.
3074
ET48.3 with M2C wide chassis, all M2C chassis braces, Castle 1515/MMX, Badlands 3.8", aluminum fans/heat sink, etc. Weight is without battery.
3075
3076
Does anyone know if the mega brace will fit on the stock chassis with an arrma blx 185 system in it ? they've been sold out of the other center brace for a while now but the brace meant for the wide chassis is in stock.
Does anyone know if the mega brace will fit on the stock chassis with an arrma blx 185 system in it ? they've been sold out of the other center brace for a while now but the brace meant for the wide chassis is in stock. View attachment 5017
I'm seeing if it'll work on a 2250 TEKIN 1/8 can......I thought the brace was for the stock chassis!
