pache
- Tekno RC's
- MT410
- Driving Style
- Basher
G'day
There's a lot of discussion about motor/esc choice, but I'm having difficulty finding much about high ambient temperature conditions (Australia).
I'm talking paddock bashing at 35-40c ambient (about 95-105F) in the open sun. Surface would be paddock (grass, varying heights), gravel road, and the possibility of some sand or dirt. I'm after fun, so runtime is significant & I'd accept some top speed loss - I'm coming from a brushed crawler, this should be fast regardless...
My initial "safe default setup" was looking like:
- Hobbywing Max8 with 4274 sensorless 2200kv
- Ideally Backflip LP, but if they don't come back in stock it'd have to be something like Badlands or possibly the 6S Backflips (too heavy?)
- I have no position on pinion size, 17T seems to be the default recommendation. Also it would be simpler for me to get non-Tekno pinions, would the Arrma pinions work ok? (e.g. ARA310964 - Mod1 17T steel with 4mm set screw)
- I'm planning on using 4S (probably 50c 5000mA bashing series)
- Receiver'll be a FS-BS6 for my Flysky FS-GT5
1) Am I even likely to have a heat issue here with this setup anyway, or am I worrying about nothing?
2) Dropping pinion size down is an obvious heat reduction, but would going down to 15 or 16 be enough?
3) Hobbywing doesn't seem to do a sensorless 1900kv at present, but they do have sensored 4274's at 1900kv & 1600kv in the old generation. Worth it? Is sensored any better/worse in heat?
4) Swapping up to a 1/6th motor had occurred to me (e.g. Max6 and EzRun 4985), but that would require a chassis swap, yeah? (I'd like to keep it more default initially... this is my 2nd kit)
I keep mentioning Hobbywing solutions because product availability is an issue here without doing international mail order - Castle seems somewhat available & slightly higher price, while Tekin is expensive very limited availability. I'd rather do it right first time though, so if overpaying or importing is what it takes then I would shrug it off & do it.
