The como is a TPPower 4060 6D Sensorted with 1650KV motor and a Hobbywing Xerun XR8 PLus G2S ESC!
Tires will be the ProLine Trencher LP 3.8!
As for the terrain or the surfaces, think primarily lawn and forest floor, tend to asphalt times and also jump over ramps is an issue!
The driving behavior should not be too nervous in any case!
Primarily it goes with the GameChanger chassis to create more space for the already quite large engine because with a length of 92mm he is already quite long and that no longer fits with the ESC in the actually intended places! There would be a solution with which the ESC can be mounted centrally offset slightly above the engine also a bracket (and so the original chassis could be used) but am not so convinced of it!
Where could or would be the shorter Game Changer chassis the best Platze for the ESC, because there would be but 2 positions for mounting as far as I know!
