Esc tape!
Slogrits
Winston Salem
What is the best esc tape? I used some heavy duty 3m double stick foam tape and the esc flew out of the bug on the second battery.
Obviously a question that is often asked enough to have its own thread...LOL
Make sure you clean/wipe down the two surfaces that will be stuck together with rubbing alcohol. That will ensure the adhesion is the best it can be. Even with dbl sticky tape I would still recommend to zip tie the esc down to the mount. You wont have that problem again and it will help save your fan from breaking sooner than expected.
amen!
I always keep a slot in my pit box tray filled with alcohol swabs, I use them to clean the beads on my tires/wheels before gluing, as well as tape prep and to clean wiring and my dirty fingers at the track too ;)
I prefer velcro.
Used Velcro, it works great. Also a zip tie for good measure.
Thanks for the suggestion. I like that if I have a problem or want to change it out I dont have to clean up double sided tape.
I used Gorilla 2 way tape and the only time I had the esc fly out was when I did the install ((without)) cleaning the surface with alcohol.
