Slogrits
What is the best esc tape? I used some heavy duty 3m double stick foam tape and the esc flew out of the bug on the second battery.
I prefer velcro.What is the best esc tape? I used some heavy duty 3m double stick foam tape and the esc flew out of the bug on the second battery.
Make sure you clean/wipe down the two surfaces that will be stuck together with rubbing alcohol. That will ensure the adhesion is the best it can be. Even with dbl sticky tape I would still recommend to zip tie the esc down to the mount. You wont have that problem again and it will help save your fan from breaking sooner than expected.
I used Gorilla 2 way tape and the only time I had the esc fly out was when I did the install ((without)) cleaning the surface with alcohol.What is the best esc tape? I used some heavy duty 3m double stick foam tape and the esc flew out of the bug on the second battery.
