I have no idea of what may or may not be an easy adaption. Like if I could make fit serpent stuff or kyosho towers? Shocks are no biggie. I have those alreadyI have not seen that done at all. It I would assume something along the lines of AE TC car towers and shocks. At least the size anyways. As far as what brand...no clue. I’m guessing there will have to be some heavy modifications made or someone out there gracious enough to fabricate something which wouldn’t be a stretch nowadays.
Most 325mm bodies from DeltaplastikUSA will work with the standard shock towers:
https://deltaplastikusa.com/8th-scale/325mm-rally
Here is a conversion I did with an Associated RC8 buggy many years ago, which uses roughly the same size shock towers as the SCT410:
That’s the thing, the most part.....going to be making a special body so I will need lower towers, that’s why I was asking if someone has something that can be made to work.......Most 325mm bodies from DeltaplastikUSA will work with the standard shock towers:
For fun mainly but doing a project with my brother. And we’re going after the 325mm wb since it appears to be the most popular.Its basically is an 1/8 vehicle so I assume you are talking about making it a 1/8 scale on road TC?
If you are determined and have plenty of spending cash I am sure you could make it happen.
Also looked into the Xray and from what I’ve turned up it doesn’t appear to be the best for the money so I’ll avoid that.
Using something like this https://www.amainhobbies.com/xray-gtxe-1-8-gt-electric-onroad-touring-car-kit-xra350600/p724850 as inspiration, makes it look pretty feasible to me. One thing to look into, that I am not sure of, is the wheel base dimensions. Would they be the same and does it matter? Are you are trying to make it to specs or just for fun?
Finding some shorter towers that fit would be ideal and probably some shorter shocks as well. Slap some street tires on it and you are almost there.
