Ifti, you will likely run into the same issue as myself (my post above) as the 2.0 battery strap is wider than what is included on the EB48.4 buggies. The tray in the EB48.4 is sized to accommodate a 2x2S configuration. Couldn't find dimensions on the 7600mAh battery you linked, but Centro's similar 4S 7200mAh pack has Dimensions (W/D/H): 137 x 49.5 x 49mm.
