48 2.0 Working on the build. Got a steering servo question.
PapawFox64
I’ve got a Savox steering servo with a 25T spline. A single sided horn should be ok but what about the length? For setup, should I use the 18mm or 20mm hole from center mounting hole? Thanks for any input.
Usually 18 mm
Tekno R/C strongly recommends using the inside (short) mounting hole for use in Tekno RC vehicles. This will make the steering response smoother and also protect your servo better.
Usually 18 mm
Thanks!👍🏻
