410.3 Stripped screws trying to access front diff
teknojim23
I'm going to do my front diff on my sct410.3 and went to take out the long 40mm screws that hold the a arms on and they are stripped. My question is do I need to remove them. It seems I do.
Yes, you do need to remove the TKR5730 40mm screws as the front diff is locked between the two hinge pin braces (TKR5730).
If the heads are stripped, you'll want to use an extractor set, such as the one @Billl DeLong mentioned above.
What hex driver are you using? Most times stripped heads are caused by cheaper or worn out drivers.
