Shocks interchangeable?
EvoX
I’m wondering if the ET48.3 and ET48.4 shocks are interchangeable? Does the vented cap make a big difference and if need be could I just change the caps to fit if needed? I’m trying to find the 48.3 shocks online and haven’t had any luck. Thanks in advance for any help given.
I don't think they've released the .4 yet for the truggy, but they do sell the "Full Option" kits for the shocks here which would be the equivalent to .4 shocks if they were to have a .4 release that is:
https://www.teknorc.com/product-vehicle/o-et48_3/page/3/
If you already have the .3 shocks, then all you need to upgrade are these parts here:
https://www.teknorc.com/shop/tkr614...nd-tall-spring-perch-set-revised-16mm-shocks/
Flat pistons, they sell blanks so you can drill your own if desired:
https://www.teknorc.com/shop/tkr6163-shock-piston-blanks-cnc-flatflat-16-dimples/
vented caps are a must for me, emulsion shocks will significantly add more traction:
https://www.teknorc.com/shop/tkr8702-shock-caps-7075-emulsionventedstandard-black-ano-2pcs/
The TiNi shafts are just gonna make the shocks a little smoother, probably not a necessary upgrade, but will probably help on rough bumpy tracks:
https://www.teknorc.com/shop/tkr6017t-shock-shafts-wtini-coating-rear-steel-2pcs/
https://www.teknorc.com/shop/tkr6061t-shock-shafts-w-tini-coating-rear-x-long-steel-2pcs/
You can do as I did and run the EB48.4 shocks on the MT or ET. Just need to swap springs as the stock EB springs are way too soft.
