rcmaniacs vs probodyrc - which unbreakable body?
bbbowers
EB48, MT410
Alright, does anyone have experience with both of these? From what I understand the rcmaniacs is the original. They are both from Russia so I want sure if one was just a reseller or if they are totally different materials.
The main reason is probodyrc I can get for about $70 (on sale). I don't want to get a knock off though if that's the case. Any suggestions?
Amateurhour
MT410
I have a body from each and while they are different bodies, they are very different in their finish. I highly doubt that they originated from the same place. The material seems similar but the finishes are much different.
I have a C10 body in black from probodyrc. It came untrimmed so I had to cut it out myself which can be good if you have a unique model and need to adjust the wheelbase. The texture is not rough, but it’s definitely not smooth if that makes sense. The bodies curves are very rounded and it doesn’t have a lot of details.
I also have a body for a savage x flux in silver from rcmaniacs. It arrived trimmed but not drilled. The finish is smooth and the curves are much sharper. It also has many more details than the probodyrc c10. I’m just a basher and the bodies are quickly scuffed so the details and finish are nice but I’m not using them on a scaler so that doesn’t really matter.
For the most part they each offer different models so it really comes down to finding the one that you like most.
Here are some pictures to try and show the differences. Silver is rcmaniacs, black is from probodyrc
bbbowers
EB48, MT410
Thank you, that is exactly what I was looking for. Do they seem to be of the same thickness? I'm guessing if they are made from the same stuff they will be similar in durability. I'm just a basher too. That looks like a clean trim job. What did you use to cut it out?
Amateurhour
MT410
The probodyrc might be slightly thicker but that could be because of the texture. They both seem very flexible. And definitely hard to trim. My lexan scissors hardly touch them. Oh and paint doesn’t stick at all.
I just used my pocket knife to trim it. Once or twice over scoring lines and then I could peel the excess back as I cut. A good set of shears might work too. A dremel works well to smooth any edges.
I’m not going to end up running the rcmaniacs so I can’t fairly comment on durability. But the probody is holding up very well so far.
bbbowers
EB48, MT410
Thank you. Probodyrc said scissors would cut just fine so that's good to know. I do like the idea of being able to cut it myself for the wheelbase. I wasn't sure if that c10 they had would fit since I know they recommend the extended body c10.
What did you use to make the window silver? I thought about just using some duct tape.
Amateurhour
MT410
The c10 fits nicely on the mt410, it’s a longbed version. If I didn’t already have a c10 on my kraton I would get another for my mt. Here’s a shot of it sitting on the mt410:
For the windows I used some adhesive backed vinyl sheets that I got on amazon. It came in a 40 pack and I used about half a sheet so I will have enough for my next 79 bodies 😆 If I hadn’t gotten the black body I would have used electrical tape and called it good. Duct tape would probably work well too.
bbbowers
EB48, MT410
That looks great! The vinyl sheets a great idea. A 40 pack would definitely do it, haha. Thanks for all the advice!
JaWise
MT410
Hi! I'm from Russia :)
I have one rcmaniacs body and two probodyrc bodies.
These are absolutely two different manufacturers.
At rcmaniacs all bodies are smooth. They said so.
Stickers stick to them better.
With probodyrc, it depends on the color. They said so.
Probodyrc has a rough blue color. The color orange is smooth.
The rough body seems thicker.
I chose the rcmaniacs body for the MT410.
It is very similar to the Pro-Line 3468-00 2017 Ford F-150 Raptor.
It is already carved.
PS English is not my native language, so please be kind to my mistakes.
WoodiE
Kind of good admin
Staff member
Kentucky
@Amateurhour have you tried putting decals on either of these bodies? I've been hearing that stickers and even paint doesn't stick to these bodies.
Amateurhour
MT410
I tried paint on the scraps of the probodyrc and none of the paints I tried stuck at all. It was actually impressive how easily I could brush it off.
I put some vinyl stickers on and used a heat gun to try and help them form to the texture of the body. So far they are holding but adhesion is just alright. I don't expect them to last forever.
Bryan
Do they have chevy bodys?
Guy unbreakable body ET48 7
Papi Chingon Best way to accurately drill mounting holes in unbreakable russian body? MT410 8
