48 2.0 No steering
Mxdad
I have a sanwa mt44 with a rx482 receiver and a hobby wing xr8 emc. Problem is it won’t turn at all, seems no input???? Any suggestions thanks in adva
If you put the servo connection into the throttle output on the receiver and pull the trigger does your servo work then? You can also try the throttle in the steering output, but be very careful because it might and is likely to take off, so disconnect the motor wires if you do.
Thanks for the suggestion I will try that tomorrow and post results thanks
So I switched the wires around and sure enough the steering works but not the motor so I’m thinking my receiver is no good
