So I switched the wires around and sure enough the steering works but not the motor so I’m thinking my receiver is no goodIf you put the servo connection into the throttle output on the receiver and pull the trigger does your servo work then? You can also try the throttle in the steering output, but be very careful because it might and is likely to take off, so disconnect the motor wires if you do.
Oh man that sucks, hope you can get a replacement receiver.So I switched the wires around and sure enough the steering works but not the motor so I’m thinking my receiver is no good
