Hi Everyone
I completed my MT410 build yesterday (which was a pleasure) and I am now thinking of what motor and ESC I should use.
Just a thought I have an Arrma Kraton 4S which no longer works (because it is rubbish, the slipper clutch will not stay tight) and I could remove the electrics from this and put it into the MT410. What do you guys think, would it be suitable? Spec's listed below. If you think this could work what pinion should I run?
If I have to buy new electrics it is not a problem, just thought I could recycle some other parts? They are quite new as the Kraton has only been used about 5 times before it gave up the ghost!!
I know it is only rated to 4S but I think this will be ok for the truck? Any help is much appreciated.
Oh yeah I am thinking of having either the Arrma backflip tyres (off the 4s outcast) or the proline badlands.
Any help is much appreciated, go easy I am relatively new to RC.
Regards
Andy
MOTOR
ESC
Regards
Andy
MOTOR
Motor Type | Brushless |
Motor Kv | 2400 |
Poles | 4 Pole |
Motor Length | 68mm / 2.68" |
Diameter | 36mm / 1.42" |
Shaft Length | 18.5mm / 0.73" |
Shaft Diameter | 5mm / 0.2" |
Motor Mounting Hole Diameter | M3 |
Motor Cable Length (Including Connector) | 45mm / 1.77" |
Motor Connector Diameter | 4mm / 0.16" |
Motor Weight | 228g / 8.04 oz |
Battery usage | 3S LiPo (11.1V) or 4S LiPo (14.8V) |
Low Voltage Cut-Off (LVC) | 3.4V per cell |
Thermal Protection Temperature | 125°C / 257°F |
Over-Voltage Protection | Over 17.2V |
BEC Voltage | 6V |
BEC Current | 3A |
ESC Length | 43mm / 1.69" |
ESC Height | 34mm / 1.34" |
ESC Width | 54.5mm / 2.15" (Including hold-down tabs) |
ESC Weight | 150g / 5.3 oz |
Receiver Wire Length | 170mm / 6.70" |
Battery Wire Length | 225mm / 8.86" |
Motor Wire Length (Including Connector) | 200mm / 7.87" |
Switch Length | 21mm / 0.83" |
Switch Width | 13.3mm / 0.52" |
Switch Height | 16mm / 0.63" |
Motor Bullet Connector Size | 4mm / 0.16" |
Wire Specifications | 12AWG |
ESC Battery Connector Type | 2xEC5 |
