Mounting servo, grommets or not
MikeBuzz
  1. SCT410
I have just received my servo from china, I have bought a AGF A80BHMW, the question is should I mount it using the grommets or just hard mount using the tabs, as I have seen people doing both, what’s the pros and cons to each?
grommets are intended for aircraft/boats when screwing into wood to prevent vibration from working the screws out, since we are screwing into plastic/metal there is no need for rubber grommets in this application.
Less us know how it works for you!
Edit: that is a feature rich, yet rather pricey servo. You can get a decent Savox brushless servo for almost the same price (although not with the same specs). Curious to what made you choose AGF?
The servo is cheap, cost me around £46 direct from China, could not see many other options around that price point
Yes sir, I absolutely love these AGF servos, by far the smoothest servo I have owned to date, I also run the shorty servo in my PR Racing 401R-T , these servos are legit!
@Billl DeLong have you installed this servo in a Tekno vehicle, I installed it today but it seems to high when mounted and the linkage between the servo arm and servo saver rubs on the servo case
have just shimmed it using an extra washer on the servo saver arm
fits like a glove in my SCT410.3, hardware assembled per the instructions, nothing extra necessary:
only just hits on full lock to the right, does the angle on the link look right?
I just raced last night and haven't had the chance to clean my truck so apologize for all the dirt, but here's a quick video demonstrating how mine is working, I noticed that you don't have the spacer on top like the manual recommends though not sure how that will effect your alignment:
maybe my manual is an old version, shows no spacers on the top
I stand corrected, looks like that's why my link is more parallel than yours, ha!
I don't see any need for the spacer below the ball link when using the aluminum servo horn ;)
