emulsion style shock install with aluminum caps
harlon
Sup tekno fam. I got my steel spur and aluminum shock caps in yester so I decided to gitter done 😁 the steel spur installed with to problems but when i built my emulsion style shocks, I ran into a few issues when following teknos vid. Im pretty sure the problem stemmed from the vid using plastic caps and i was using aluminum caps. In the end I figured it out and now I am in love with these shocks! They're butter smooth. I made a vid of me doing the install. Check it out if your having issues with emulsion shock setups. Im sure there will be some professionals cringing watching me do this.😄 but it seemed to have worked very well. Check it out and give feedback if you think i can do something better. Thanks guys 🙂👊
harlon M2c zrs shocks caps or tekno emulsion caps.🤔 MT410 5
Nicochau 48.4 Bladder vs Emulsion shocks EB48 6
Slogrits Emulsion shocks MT410 14
J 48.3 Want to put a MT style body on my 48.3 ( Please Help ) EB48 0
Slogrits What style of indestructible bodies fit the MT410? MT410 9
S Shock Oil EB48 14
Will Shock pliers or crab crackers? Tools 3
ReMiXeDg vented or non-vented shock caps MT410 4
R Shock seals and shock shaft protection EB410 4
HeavyBag Alternative Shock O-rings ET410 9
B Shock mount screw upgrade? EB410 1
I Shock Cover ET48 9
F Shock and Differential Questions MT410 0
C Shock building help MT410 2
S Shock settings for big air ET48 9
2 Crappy finish on shock towers??? ET48 8
Slevin What shock oil are you running for bashing? ET48 3
WoodiE Tekno Shock Standoffs Chassis & Drivetrain 1
tooshay Shock issues? MT410 5
Tamiyauberalles What would be the most useful test to run on shock oil using a 100k$ viscosity testing apparatus? Chassis & Drivetrain 2
S What shock weight would you suggest? SCT410 6
S Wrong shock bodies on EB48.4 EB48 9
S Which aluminum shock cap? MT410 3
Slogrits Upper Plastic Shock tower body mount brace. MT410 13
WoodiE Tekno EB410 Carbon Fiber -2 Shock Rear Tower from VRP EB410 0
WoodiE Rear EB410 carbon fiber shock tower EB410 3
Slogrits Shock setup. MT410 12
Illestep3 Shock oil setup Chassis & Drivetrain 16
