Eb48.3 pinion
VRC
Hello everyone,
I’m new to Tekno. I am getting back into the hobby after many yrs. Back in the late 80’s-90’s. Had an original rc10, 12i, frog, Willy and silver fox nitro. Got out of it cause I couldn’t afford it and was, well in high school looking at skirts! Anyways, I have an eb48.3 which I’m amazed by. It’s all stock. I’m going to be mostly bashing around with it. My question is what is the smallest pinion I can run in this? I tried a 14t for small spaces It doesn’t fit cause it seems the motor mount doesn’t allow anymore movement towards the spur gear. Is my assumption correct? That, it is to small or am I missing something? Thanks for the help in advance. Looking forward to enjoying the hobby again 🙂
smirkracing
EB410, EB48, ET48
I don't have that platform anymore but I am pretty sure 15t was the smallest I could fit. I went at the motor mount with a dremel and shaved a LOT of material, but could never get it to fit anything smaller than 15t.
You'll need to adjust your motor KV and your battery selection to work with the constraints on the pinion size (in summary, you may want to consider lower kv that you might otherwise).
EB410, EB48, ET410, SCT410
@smirkracing is correct about a 15t being the smallest fit as is. But I have heard of people grinding off a small part of the motor mount to allow it to slide a touch further.
What size motor are you running? Why do you want that small of a pinion?
VRC
I’m running a 2050kv. Well, I haven’t played with pinions yet on the car and wanted to see the difference. Currently has an 18t. For small space running.
16t-17t is probably a good place to start with that motor while running in a small area. Maybe a 15t if you feel you have too much tire spin still.
I use to run a 17t in my EB48.3 w/ a 1900kv motor, running on a smaller track. It seemed to be about perfect for me. There are a couple small run ups leading into a couple big jumps and only a small straight away and probably could have been good dropping to a 16t. I like the smaller pinions for the reason, being its easier to get to speed faster on a smaller track.
Edit; Track was also a fairly hard packed track with lots of loose dirt on top.
  • Like
Reactions: VRC
Steve B in Vegas Blasphemy...., but are there other wide chassis options for the EB48 Chassis & Drivetrain 12
Megafandrew 48 2.0 EB48 2.0 updates worth an upgrade EB48 7
G 48.4 EB48.4 All 4 Bearings Done EB48 8
R 48 2.0 Need some help with bag i EB48 2.0 EB48 13
A New EB48 2.0 EB48 2
Kronuxx EB48 2.0 gearbox mount holes? EB48 6
S 48.4 EB48.4 Ride Height EB48 2
Sludog Tower hobbies has EB48 2.0 in stock.......Hurry if you want one EB48 5
Kinbar the Angry Toaster EB48 2.0 and Protek 170 SBL Servo EB48 3
Ifti 48 2.0 Tekno EB48 2.0 Complete Video Build Guide! EB48 24
S 48.4 First Tekno kit. EB48.4 EB48 3
N First build eb48 2.0 RC Builds 7
Stevie'sDad03 EB48.? EB48 7
T Eb48.4 vs eb48 2.0 EB48 12
N 48 2.0 Esc dimensions eb48 2.0 EB48 9
J 48.3 Help with steering please (Eb48.3) EB48 7
HeavyBag EB48 Picture Thread EB48 33
TBuggy 48 2.0 TBuggy's EB48 2.0 EB48 50
Ifti EB48 2.0 Electronics Setup? Electronics 50
Y 48 2.0 First ever kit completed: EB48 2.0 :D EB48 8
Nicochau EB48.2 spindles upgrade EB48 5
R EB48.3 noise levels EB48 3
Y EB48 2.0 Setup sheet PDF? EB48 3
DangerD EB48.4 or 2.0 EB48 15
Ifti EB48 2.0 or EB10.2 ? RC Builds 9
Jared wagner Eb48 2.0 / mt410 MT410 0
G 48.4 Anyone have m2c on eb48.4? EB48 4
TBuggy EB48 2.0 EB48 16
H EB48.2 and EB48.3 Parts Compatibility EB48 6
B EB48.3 or .4???? ET48 4
Nicochau Would you recommend EB48 “.1” to a friend? EB48 1
E EB48 2.0 EB48 4
Budki Sct410/ EB48 parts list SCT410 13
Tamiyauberalles 2.8 1/10 Monster Truck tires on EB48? EB48 27
Overkill Monster EB48.3 buggy RC Builds 50
S Basher buggy build: ET48 to EB48 conversion? Parts list? ET48 4
D I want to use Exotek hubs on my EB48.3 EB48 10
Tamiyauberalles Got a used EB48.4 but the body is shot, options? EB48 7
Tamiyauberalles MT410 - EB48.4 common parts? EB48 3
matimath Rumors of a Tekno EB48.5 EB48 22
B Best wing for EB48? EB48 3
Nicochau Wheels rubbing on EB48.4 EB48 2
C 48.4 EB48.4 is fantastic EB48 9
Bastien Eb48 to desert buggy EB48 12
C EB48.4 to SCT EB48 8
StevieGT 48.4 95% done with EB48.4 EB48 19
cdaxj Question about SCT410 vs EB48.4 SCT410 6
StevieGT EB48.4 Couldn’t resist RC Builds 14
D Buying EB48.2 EB48 5
TBuggy Tbuggy's EB48.3 EB48 7
