Benlee1012
Hey guys,
I'm almost finished with my ET48 2.0 build. I watched a build series on YouTube. There's mention of the whole driveline being super smooth. I wouldn't think anything of it if this was a cheap kit with large tolerances.
The issue is when I try to spin the driveline by hand (either spinning the spur gear or wheel hexes, I can feel a slight loosening and then tightening. I appears to come and go every 2-3 turns of the spur gear. It's only slight but you can definitely feel it.
The only thing I can think of is that the front and/or rear diff ring gears are wobbling, so it's mesh with the diff pinion is getting closer and then further away if you know what I mean. Everything felt fine as I was building the diffs and shimming them to the diff housings. Front diff took one shim and rear diff couldn't take any shims.
Anyone experience this issue before?
Thank you for your help.
