First post bash report, not too happy..? I broke the unbreakable Tekno (sort of) ..!!
So I finally got outdoors to run the MT.. I went with the Copperhead 2's an Arrma BLX esc/motor running 15T pinion and a 6s 4000mAh 60c battery..
To start with it doesn't do standing backflips like everybody said it would ?? not very impressed at all.
I know the battery is low mAh but I run the same setup in my Typhon and it rips..!!
So I'm guessing it's not the battery, I have esc set at max punch as I do on all my rigs,
I'm starting to think that maybe the Copperheads are too large ?
I'm having trouble trying to understand how people with only 4s can do standing backflips..??
Do I need bigger battery, better esc, bigger motor..??
Anyway putting that aside, the handling of this truck is awesome and once it's moving it's nuts ? it's so fast.!! It just soaks up all the rough terrain like it wasn't there..?? those Tekno shocks truly are the best on the market as far as I'm concerned..
All in all it was going great until I noticed the truck seemed a bit loose and wobbly, the fun time was over, on to the breakage...!!
It was only minor but I think people should keep and eye on this problem if they own a MT.
So what had happened was the locknut had worked loose allowing the turnbuckle to move up and down, back and forth..!!?
The damaged was the bolt and ball, lucky I had some spare balls to hand from when I modded my Infraction..
I've never bent my balls before..????
When I got home I took the truck apart because I wanted to check the rest of the locknuts, to my surprise I was able to completely screw the locknuts on by hand just with my fingers..!! so the locknuts weren't actually locking, easy fix though as I have some better M3 locknuts fitted now that I can't just screw on by hand..?
I checked the other locknuts on the shock standoffs and they were loose also, they were fixed with a small amount of loctite as I don't have any M4 locknuts with flanges..??
I'm going to replace all the Tekno locknuts soon..!!
( shame on you Tekno for supplying ? nuts )
That's it for now, only a small problem but a problem none the less..?
