SOLD / FOUND Unused Tekno 48.3 SOLD
Status
Not open for further replies.
jcjc
Selling my Tekno 48.3 and accessories. I built this truggy and have never used it aside from indoors for a couple of minutes to verify that it worked properly. It's been collecting dust ever since. Of the two batteries, only one was used for the indoor test and both were put into storage mode right away.
Here's a partial list of parts. I say partial because all of the M2C Racing parts aren't listed but can be seen in the pics.
Well over 3K spent.
Make a reasonable offer and it's all yours. I also have bags of random parts and extra parts that I'll include.
parts list:
1 x FUTK1410
Futaba 4PLS 4-Channel 2.4GHz T-FHSS Telemetry Radio System w/R304SB Receiver
$209.99
1 x PTK-370TBL
ProTek RC 370TBL "Black Label" Waterproof High Torque Brushless Crawler Servo
$159.99 [Add Review]
1 x PTK-5106-17
ProTek RC 4S 100C Silicon Graphene HV LiPo Battery (15.2V/6500mAh)
$174.99
1 x PTK-8522
ProTek RC "Prodigy 610ez AC/DC" LiHV/LiPo Balance Battery Charger (6S/10A/100W)
$65.99 [Add Review]
1 x TEKTT2332
Tekin RX8 GEN3/Redline T8 GEN3 1/8 Buggy Brushless ESC/Motor Combo (1900kV)
$314.99 [Add Review]
1 x TKR5602
Tekno RC ET48.3 1/8 Electric 4WD Off Road Truggy Kit
$599.99 [Add Review]
2 x CSE095-0008-00
Castle Creations 5.5mm High Current Bullet Connector Set
$19.98
1 x TEKTT2332
1 x TKR5149A
Tekno RC Aluminum Differential Cross Pin (6) (Used w/TKR5150)
$15.49
1 x TKR5237
Tekno RC Composite Spur Gear (44T)
$7.99
1 x TKR5262
Tekno RC CNC Aluminum Split Center Differential Mount (Gun Metal)
$40.99
1 x TQW1103
TQ Wire 10AWG Wire 1' (Black/Red/Blue)
$10.99
1 x M2C6900
M2C Tekno Electric Aluminum Center Differential Case
$38.49
2 x DTXC3660
DuraTrax X-Cons 1/8 Mounted Truggy Tire (White) (2) (Zero Offset)
$65.98
1 x TKR4176
Tekno RC "M5" Hardened Steel Mod1 Pinion Gear w/5mm Bore (16T)
$11.99
2 x TKR5071C
Tekno RC Aluminum 17mm Lightened Hex Wheel Hub Set (Gun Metal) (2) (+2mm Offset)
$29.50
1 x TKR5116C
Tekno RC Aluminum 17mm Serrated Fine Thread Wheel Nut (Gun Metal) (4)
$22.49
1 x TBR570071
T-Bone Racing Tekno ET48 NM Front Bumper
$12.99
1 x TBR570101
T-Bone Racing Tekno ET48 NM2 Rear Bumper
$12.99
1 x TKR5253B
Tekno RC Aluminum Single Sided Clamping Servo Horn (25T)
$15.25 [Add Review]
TKR6140C TKR6140C - Locking Shock Rod End and Spring Perch Set (updated 2019, 16mm shocks)
TKR8727 TKR8727 - Shock Standoffs (2pcs, requires TKR8730)
2 $22.48
TKR8730 TKR8730 - Shock Cap Bushings (4pcs, requires TKR8727)
1 $4.49
TKR1226 TKR1226 - 5x7x.2 Shims (10pcs)
1 $2.99
TKR5116 TKR5116 - Wheel Nuts (17mm, serrated, gun metal anodized, M12x1.0, 4pcs)
1 $11.24
TKR5143 TKR5143 - Differential Seals (3pcs)
1 $2.99
TKR5070A TKR5070A - Stub Axles (aluminum, 2pcs)
1 $18.74
TKR5114XB TKR5114XB - Differential Outdrives (front/rear, revised, lightened)
1 $16.49
TKR1103 TKR1103 - Turnbuckle Wrench (4mm / 5mm, hardened steel)
1 $11.24
TKR5020 TKR5020 - Hinge Pins (inner, front/rear)
1 $7.49
TKR5034 TKR5034 - Hinge Pins (outer, rear)
1 $8.99
1 $18.74
1 $16.49
TKR5199B TKR5199B - HRC Rear Hubs (L/R, CV or uni, EB/NB/ET/NT48/48.3)
1 $8.99
TKR5430 TKR5430 - Suspension Arms (rear, 2pcs, ET48, NT48)
1 $13.49
TKR5436 TKR5436 - Suspension Arms (front, 2pcs, ET48, NT48)
1 $13.49
TKR6017T TKR6017T - Shock Shafts w/ TiNi Coating (for 122mm shocks, steel, 2pcs)
1 $14.99
TKR6061T TKR6061T - Shock Shafts w/ TiNi Coating (for 137mm shocks, steel, 2pcs)
1 $18.74
TKR6146B TKR6146B - Shock Cartridge Set (CNC, Delrin, revised, all 16mm shocks)
1 $14.99
Pics:
Reasonable aka fair.
Price reduced to 1650 here and sent to all watchers/people that made offers on eBay.
Status
