48.4 EB48.4 Ride Height
SHouck
Ok so I rebuilt both rear shocks. I could see no issues with either. No bent shafts and O-rings are all in Great shape. However when I drop the car to check Ride Height it's Different every time. Is this a issue or common.
Ok!!!! So I measured everything a dropped the car hopefully the same around about 6 inches each drop. I have 24mm front and back. What would be a good stable ride height for a rough Covered but outdoors track. I have orange springs on rear black on front. 550 oil front and 550 rear. From shock adjustment to top of threads is 14.43mm Front measurement is 10.52mm.
I presume you are intended to continue discussion from this thread here:
https://www.teknoforums.com/threads/shock-oil.1695/#post-14326
for clarity of the discussion, I will continue discussion on that thread to avoid cross posting which can make things more confusing
