Diff cracking
Luke Huber
Just built a tekno e Truggy 2.0, my rear diff makes a loud cracking noise when accelerating fast on the ground but not in the air. This causes there to be less torque because it seems something is slipping. I thought it was a blown spur gear so I replaced but it started happening again. I’d be so thankful if someone could tell me what is causing this and how to avoid it.
just a guess, but I would check the bulkhead for cracks, they are a known weak point, though typically the front bulkheads are more common to break.
Try shimming the ring gear closer to the pinion. The case can flex and allow the gears to "skip" if they don't mesh deep enough. I had the same issue on my ET.
I put two shims and it worked great for a little but the problem is happening again
Once the ring and pinion gears start to strip out there's not much that can be done to save them unless you fix the mesh immediately at the first sign of skipping. I would replace them as soon as possible with a new set and when you install the new gears adjust the mesh so that they're slightly on the tighter side. The gears will wear in and free up after a couple of runs.
If you have any other broken Tekno parts I would send them all in together for warranty.
