Not sure, just give tekno a call. Possibly, as teknos website says TKR9660 works with the MT48 aswell@headsmell
Nice looking ET you have there and thanks for sharing.
I don't think I have the proper tapping tools or skills for that modification lol.
Happen to know if the following parts will fit on the ET48.2.2?
https://www.amainhobbies.com/tekno-rc-sct410-2.0-skid-plate-bumper-cushion-tkr9660/p1528801
https://www.amainhobbies.com/tekno-rc-sct410-2.0-bumper-set-tkr9680/p1528802
Trying to complete my purchase with Amain as I was provided a 20% discount code![]()
Thanks for chiming in, Matthew! My new kit is arriving on Monday to include the Tekno front and rear steel skid plates. In addition to the bumper assemblies I mentioned above, will the wheelie bar fit as well with no problem? I plan to run 6s on the ET48 and 18t pinion at my own risk lol.The MT410/MT48 bumpers bolt up to the ET48 no problem. You'll want to use the longer screws that the MT calls for though. I think it's M4x25 in place of the M4x20 and M4x20 in place of the M4x15. I also suggest putting the thin steel skidplates we sell on there too. By running the steel skids (chassis, plastic skid/bumper, then steel skid) you will increase the life the plastic skid/bumper and the steel skid prevent the screws from going too far into the plastic and deforming the holes.
Hi Matt,The MT410/MT48 bumpers bolt up to the ET48 no problem. You'll want to use the longer screws that the MT calls for though. I think it's M4x25 in place of the M4x20 and M4x20 in place of the M4x15. I also suggest putting the thin steel skidplates we sell on there too. By running the steel skids (chassis, plastic skid/bumper, then steel skid) you will increase the life the plastic skid/bumper and the steel skid prevent the screws from going too far into the plastic and deforming the holes.
It will bolt right up but you might have to remove the wing mount or run it in the high position.Hi Matt,
I also bought the ET48 2.2 kit and am planning to put a rear bumper on it for bashing. Can you confirm if the bumper cushion of TKR9660 screws in directly into the stock ET48 2.2 rear shock tower without any modifications? Thanks for your assistance.
I wouldn't want to remove the wing mount to install the MT48 rear bumper cushion. I would need to determine if it could still be mounted by moving the wing mount to the high position. thanksIt will bolt right up but you might have to remove the wing mount or run it in the high position.
I measured it and the MT48 bumper cushion will not mount up to the ET 48 2.2 shock tower. The distance between the lower wing mount holes of the ET 48 2.2 shock tower and the chassis base is about 2 3/4"; whereas, the distance between the bumper cushion mount holes in the MT48 shock tower and the chassis base is about 2 1/4".It will bolt right up but you might have to remove the wing mount or run it in the high position.
