Battery Heat Shrink
rfulcher
Greencastle, PA
  4. MT410
  5. SCT410
Does anyone know where you can get large clear heat shrink to go around a whole lipo battery. I have several batterys and the labels are rubbing off and some where there is a hole developing through the heat shrink on the pack. I was hoping to start putting a clear heat shrink around it and I can replace as it gets damaged.
Soooo….. you are considering putting a flame to a Lipo that has a hole in it?
You may want to think twice about that. Granted the shrink tube is covering the damaged area, but……
Man, you folks are dedicated. I just use a few tight wraps of clear packing tape to "re-seal" the lipos (esp. hard cases). Holds up pretty well actually.
I do the same thing to my packs, I usually go one step further and shrink wrap them BEFORE I even first run them. Helps keep the sticker intact and the pack looking nice. Ill usually re wrap them every few months or if the wrap gets damaged.
That is a good idea. I will start doing that.
