45T vs 44T spur
I’d keep the stock spur gear. Is there a reason you are looking at the 45t Lodi one?
Gearing options I guess. I guess if I ever decided to race I would go higher tooth count anyway. 1700kv motor.
I’d stick with the stock spur gear and go from there. It is generally wise to have different pinions on hand when racing. Not sure I would really mess with the spur gear. On a 2wd it is easier but 4wd I’d rather just mess with the pinions. If you are going to run a 14t or smaller than I can see the necessity but with a 1700kv motor your likely to run a bigger pinion.
Thank you!
