Thanks bro. I want to change the strips on the tray.When TEKNO first started out, they provided conversion kits for various brands of cars to convert from nitro to electric. It took a while before TEKNO finally created their first car themselves. While I don't believe this battery tray will be a direct fit for the ET48, it's possible that it may work on the NT48 chassis which is different from the ET48 chassis. Since the ET48 already has a custom spec tray, I don't understand why you would want to replace it?
This hapen becous i jumps allot. The battery move back little bit and corved becoas the small plastic on the trayI would replace the OEM tray, and if there is any gap between the battery and the front edge of the tray, then I would place a shim there to help fill the void. Cut a scrap piece of plastic, I have used a plastic servo horn from the kit as a spacer too.
Also very important to use all 3 velcro straps
Perfect dude ????You could also build a battery holder using Kydex.
Picture is credit of forum member @Overkill (hope you don’t mind me sharing)
