Proline screw on body mounts
JTRC
What is everyone using for the MT410 for the screw on body caps and posts? I’m not finding one made for the mt410
I have not seen anything specific for the MT410. Those prolines will work you just need modify the mounting supports on the towers so you can screw them in.
If you can find them
Proline used to make a set for the sct410 .
Anyone know how to runs these body screws with the M2C thick shock towers? Needs a bar/beam and screws. Saw the relevant pics from Overkill, but no specifics.
Answered my own question... With the thick M2C shock towers you should run the Arrma body posts as recommended by M2C. You then need to cut/sand the circlip tips off flat and drill them for the M4 set screws.
