Kozzy
Hello all,
I'm looking for some advice to resolve this issue that I'm currently having at the track (after the track and weather changed)
The track is dirt, medium/high grip, bumpy with tight corners.
The issue:
OverSteer when entering a corner. (many times the car would spin in place) and overall unstable car.
After many changes that I tried, I eventually reverted to the stock setup except for the following:
Diffs: F10K,C7K,R7K
Shock oils: F400cst R500cst (emulsion)
Sway-Bar: R2.6 F2.5
Tires: TZO 402/601/500 Super-Soft/Soft
Everything else (Camber,Toe,Droop,RideHight... and all links positions) is according to the stock setup.
Without explaining here what I've already tried, what would you recommend to try in order to have the most impact?
(considering it's not the transmitter settings and that there are no parts/assembly issues in the car as far as I can see)
Thank you
The issue:
Diffs: F10K,C7K,R7K
Sway-Bar: R2.6 F2.5
Thank you
