I am test fitting my esc into my chassis tub and am running into an issue. The esc is an XR8 Pro G2 and and the on/off switch and receiver wires have a small rubber seal that sticks out a little. The way I want to mount it is with the external capacitors towards the outside plastic, not inside toward the main drive shaft. I don't want to remove the seal and compromise the electronics inside. What I was thinking was maybe dremel a small slot in the plastic side wide enough to let the wires stick out a little then fold them back over to the inside to run down to the receiver box. Once it's all in place and looks good and clean I was thinking of a small piece of black Gorilla tape to cover it up. Thoughts?
