410 2.0 Hinge Pin Braces "A,B,C,D Blocks"
central PA
  2. ET410
  3. SCT410
So, if I'm seeing things correctly...
The stock setup is based off the center position of the -1mm A,B optional blocks for the front. For the rear, the stock setup is based off the center position of the -2mm C,D optional blocks.
Is this correct?
What are the benifits of the different hinge pin braces in regards to the I assume the offset of -1 and -2?
What is the stock offset for the SCT410 2.0?
TKR9161B - Hinge Pin Brace (CNC, 7075, -1mm LRC, EB/NB48 2.1, A Block)
TKR9162B - Hinge Pin Brace (CNC, 7075, -1mm LRC, EB/NB48 2.1, B Block)
TKR9163B - Hinge Pin Brace Hinge Pin Brace (CNC, 7075, -1mm LRC, C Block)
TKR9163C - Hinge Pin Brace (CNC, 7075, -2mm LRC, EB/NB48 2.1, C Block)
TKR9164B - Hinge Pin Brace (CNC, 7075, -1mm LRC, EB/NB48 2.1, D Block)
TKR9164C - Hinge Pin Brace (CNC, 7075, -2mm LRC, EB/NB48 2.1, D Block)
