410 2.0 Hinge Pin Braces "A,B,C,D Blocks"
Pennsylvania, USA
So, if I'm seeing things correctly...
The stock setup is based off the center position of the -1mm A,B optional blocks for the front. For the rear, the stock setup is based off the center position of the -2mm C,D optional blocks.
Is this correct?
What are the benifits of the different hinge pin braces in regards to the I assume the offset of -1 and -2?
What is the stock offset for the SCT410 2.0?
TKR9161B - Hinge Pin Brace (CNC, 7075, -1mm LRC, EB/NB48 2.1, A Block)
TKR9162B - Hinge Pin Brace (CNC, 7075, -1mm LRC, EB/NB48 2.1, B Block)
TKR9163B - Hinge Pin Brace Hinge Pin Brace (CNC, 7075, -1mm LRC, C Block)
TKR9163C - Hinge Pin Brace (CNC, 7075, -2mm LRC, EB/NB48 2.1, C Block)
TKR9164B - Hinge Pin Brace (CNC, 7075, -1mm LRC, EB/NB48 2.1, D Block)
TKR9164C - Hinge Pin Brace (CNC, 7075, -2mm LRC, EB/NB48 2.1, D Block)
The box stock setup in the manual says it gives 1 degree of anti-squat. However center pills on a -1 C block and -2 D block (equivalent to the kit blocks) gives 2 degrees anti-squat on the EB48 2.2, and in both the EB and the SCT, the blocks sit flat on the chassis. The spacing between the blocks is the same in both the EB and SCT since the pins are identical.
So is the *actual* anti-squat in the box stock SCT setup 2 degrees?
The EB48 2.2's hinge pin braces are -1mm C Block and a -2mm D Block
The SCT410 2.0's hinge pin braces are comparable to a -2mm C Block and a -2mm D Block
